TwinTurbo.NET: Nissan 300ZX forum - My car had the same problem. I did the same (reduced
Subject My car had the same problem. I did the same (reduced
Posted by olyar15 on January 07, 2008 at 5:49 PM
  This message has been viewed 228 times.
In Reply To Accelerator Cable Adjustment Reduced Driveline Kickback posted by Gordo 93TT Daytona on January 07, 2008 at 05:24 PM
Message slack in throttle cable) and also found that it helped. I also checked the throttle plates and made sure that they were opening at the same time. There is a procedure described in the FSM for calibrating the operation of the two throttle plates. It requires a dial indicator, but I found that my driver side throttle plate was opening much later than the passenger side because there was far too much free play in the linkage. Check that and see if it helps.
Charles
Carbon Black '95 TT **sold**
Carbon Black '03 BMW M5
'02 Honda CR-V dogmobile
