TwinTurbo.NET: Nissan 300ZX forum - Addition to the PCV reroute mod.
Subject Addition to the PCV reroute mod.
Posted by Woody75 (Denver) on November 29, 2007 at 9:26 AM
  This message has been viewed 4482 times.
Message The mod can be found here:
PCV Reroute
This is reference to plugging the drivers side exhaust valve cover. I mentioned in the write up that some members had use Freeze/Expansion plugs to plug the holes left. I never had pictures before. I decided to try this on a recent build I did for a customer.
I picked these up at Napa. They are the 5/8" size. They are pretty cheap, around $.50 each so I just bought the whole box as I'll be using this process from now on.
They simply press into the openings on the valve cover. They are a very good and tight fit. I used a slight coating of RTV around the edges of them to make sure they had a good seal, but I'm pretty sure that it's not needed as tight of fit there was.
To aid in putting them in, a Craftsman 10mm socket end hand wrench came in very handy. It fit inside the rim of the plug. Then I just used a mallet to press them into place.
Figured others may want to try this method as well. Very clean and simple install.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
