TwinTurbo.NET: Nissan 300ZX forum - In general
Subject In general
Posted by spyhunterTT(nj) on September 03, 2007 at 7:30 AM
  This message has been viewed 213 times.
In Reply To Re: not true posted by flash-to-pass on September 02, 2007 at 09:30 PM
Message there are 2 OEM crank pullies/harmonic dampeners, the difference being the section for the powersteering belt, 3 rib vs 4 rib
there are 2 OEM power steering pullies, hydraulic hicas is a 4 rib, all others are 3 rib.
there are also 2 aftermarket power steering pullies made by UR, comes in a 4 rib or 3 rib.
Almost all aftermarket crank pullies are setup for the 4 rib belt to make it easier for the manufacturer to just make one pulley as there really is no need for two. You can use a 3 rib belt on a 4 rib pulley just fine
Alex
