TwinTurbo.NET: Nissan 300ZX forum - Re: Re: not true
Re: Re: not true
flash-to-pass
on September 02, 2007 at 9:38 PM
Re: not true
posted by flash-to-pass
on September 02, 2007 at 09:30 PM
You said hydraulic HICAS...that would be 90-93. I have a 94, so its electric, which may explain the narrower pulley.
AMS underdrive pulley - P/S belt misconfiguration?
flash-to-pass
20:40:30 09/02/07
I had the same problem
na300zx (OH)
20:52:05 09/02/07
Re: I had the same problem
flash-to-pass
21:01:45 09/02/07
no problems here
na300zx (OH)
06:25:21 09/03/07
made me go look @ mine
BlackholeZ
21:06:39 09/02/07
Re: made me go look @ mine
flash-to-pass
21:11:56 09/02/07
well you don't have to wait.
BlackholeZ
02:46:29 09/03/07
it's a 90-93 TT belt
spyhunterTT(nj)
21:18:14 09/02/07
Re: it's a 90-93 TT belt
flash-to-pass
21:21:17 09/02/07
no problems (n/m)
spyhunterTT(nj)
21:24:14 09/02/07
One P/N for all models at Courtesy
flash-to-pass
21:24:32 09/02/07
not true
spyhunterTT(nj)
21:26:25 09/02/07
Re: not true
flash-to-pass
21:30:25 09/02/07
Re: Re: not true -
flash-to-pass
21:38:00 09/02/07
There ARE two part numbers for pulleys
flash-to-pass
22:47:26 09/02/07
In general
spyhunterTT(nj)
07:30:47 09/03/07
Re: In general
flash-to-pass
08:46:55 09/03/07
You have the right pulley, you just need the right belt (n/m)
spyhunterTT(nj)
09:36:13 09/03/07
We have the correct belts
Russell@Z1
21:26:00 09/02/07
Re: We have the correct belts
flash-to-pass
21:31:41 09/02/07
Well you have a 1994 + TT which uses the NA pws pump (n/m)
Russell@Z1
21:52:30 09/02/07
Re: Well you have a 1994 + TT which uses the NA pws pump
flash-to-pass
22:04:22 09/02/07
It really isn't sloppy. It stays on the two inner ribs
na300zx (OH)
06:29:07 09/03/07
flash-to-pass
22:17:38 09/02/07
Oh, and I have a used 90-93 TT PS pulley you can have
na300zx (OH)
06:30:49 09/03/07
I don't think the pullies interchange properly.
Russell@Z1
09:48:41 09/03/07
Re: I don't think the pullies interchange properly.
flash-to-pass
09:56:04 09/03/07
You can not use a TT pulley on the NA pump. There is nothing
YugoBernie (NoVA)
13:58:55 09/04/07
Why do aftermarket parts always have problems like this???
Spongerider :)
13:35:29 09/04/07
Dont bother trying to use a TT pulley on a NA pump
Chad M (CeeLo)
00:30:45 09/05/07
