TwinTurbo.NET: Nissan 300ZX forum - That solder joint looks cold (imho)
Subject That solder joint looks cold (imho)
Posted by Ted (92TT) on July 08, 2007 at 1:47 PM
  This message has been viewed 402 times.
In Reply To Injector connector splicing technique posted by vorpalZ on July 08, 2007 at 11:45 AM
Message There should be no 'bumps' and the solder should flow easily and coat the wire evenly if properly heated. You should hold the iron to the back side of the exposed wire, then touch the solder to the front side of the wire. The solder should melt and spread with no additional effort. If not, the solder iron is not hot enough, the tip is too small, or the solder is the wrong type.
Yours might be ok, it's hard to tell from the picture, but it does appear that the joint is 'cold' (i.e. brittle). The splice technique looks good though and should promote good solder flow if properly heated.
Ted
