TwinTurbo.NET: Nissan 300ZX forum - Some input
Subject Some input
Posted by ThunderZ on June 14, 2007 at 8:55 PM
  This message has been viewed 127 times.
In Reply To EGR Solenoid vacuum line posted by TTFairladyZ on June 11, 2007 at 07:25 PM
Message Would there be any effects if the vacuum line as well as the egr solenoid pictured here in blue were removed:
>>>Possibly. You should at a minimum block off the plenum ends. Just cut off the pipes at the rear corners w/ a dremel, then cut the pipes again 1/2" at the plenum ends, then fill w/ JB Weld. You can do the JB Weld in the open rear corner pipes also.
The actual EGR Valve unit as well as the tubes under the plenum will still be attached.
>>>It is OK to disconnect the vac hoses and the connector since the pipes will be blocked off anyway.
Will the EGR valve become a boost leak if the metal vacuum line is left open in the rear of the motor?
>>>Not if you block off the plenum as stated above.
