TwinTurbo.NET: Nissan 300ZX forum - Re: EGR Solenoid vacuum line
Subject Re: EGR Solenoid vacuum line
Posted by 300zxtt94 on June 11, 2007 at 7:51 PM
  This message has been viewed 294 times.
In Reply To EGR Solenoid vacuum line posted by TTFairladyZ on June 11, 2007 at 07:25 PM
Message :Would there be any effects if the vacuum line as well as the egr solenoid pictured here in blue were removed:
:The actual EGR Valve unit as well as the tubes under the plenum will still be attached.
:Will the EGR valve become a boost leak if the metal vacuum line is left open in the rear of the motor?
well my mechanic removed my EGR. and i only have one of those box's PER side. so on your pic is the blue one egr? if so than what is the other one. do you have your service manual?
