TwinTurbo.NET: Nissan 300ZX forum - And the fact ethenol absorbs moisture. (n/m)
ni[X]it
on April 03, 2007 at 6:27 PM
I think it has more to do with the corrosive properties of
posted by aliaZ
on April 03, 2007 at 04:52 PM
Why do my injectors keep failing?
cjm300zxtt
15:44:20 04/03/07
you need to upgrade to the later style injectors
aliaZ
15:57:08 04/03/07
So its the fuel that is causing this problem?
cjm300zxtt
16:01:46 04/03/07
Ethanol does not lubricate like gasoline, so it
na300zx (OH)
16:03:32 04/03/07
So I have 6 brand new injectors that will fail.
cjm300zxtt
16:08:59 04/03/07
Add Marvel Mystery Oil to every tank of gas.
robo (sebring1970)
20:44:55 04/03/07
That's a fascinating hypothesis... any backing data? (n/m)
Jehannum
16:17:51 04/03/07
2nd!! Hard to imagine how the coil can be affected by the
Zirvana
16:20:23 04/03/07
Think of it like this
na300zx (OH)
17:35:26 04/03/07
But is there any proof that the lubricity is different? (n/m)
Jehannum
09:07:58 04/04/07
Search posts by PEwithaZ (n/m)
21:54:12 04/05/07
Think of it like this: The valve in the fuel injector is
Zirvana
09:19:16 04/04/07
Re: Think of it like this
puntman87
11:49:25 04/06/07
aliaZ
16:52:11 04/03/07
And the fact ethenol absorbs moisture. (n/m) -
ni[X]it
18:27:55 04/03/07
That sounds more reasonable.
Jehannum
09:09:00 04/04/07
I believe that the ethanol additive is only available in a
Zirvana
16:11:36 04/03/07
ALL pump gas now has ethanol in it (n/m)
na300zx (OH)
16:14:56 04/03/07
I find that hard to believe, when in Nebraska all pumps
Zirvana
16:18:38 04/03/07
You are right, after I searched google, i found that
na300zx (OH)
17:42:56 04/03/07
No ethanol laced gas in my area.
yobobrox
18:04:05 04/03/07
Nismo is based in japan. No ethanol. (n/m)
nemo1080
00:02:29 04/06/07
I live in St. Louis and our pumps say 10% as well and I...
cjm300zxtt
16:38:45 04/03/07
Forgot to say the 2 extra new injectors I have ohm at 11.0 (n/m)
cjm300zxtt
16:41:23 04/03/07
No. 4 failed on my 94TT at about 221K miles. I pulled the
Zirvana
16:54:41 04/03/07
It's all over New England (n/m)
21:55:45 04/05/07
So was the later style designed to be Ethanol compliant? (n/m)
21:57:23 04/05/07
Ethanol. That's why I buy non-Ethanol gas for my pintle
ThunderZ
17:20:10 04/03/07
Where do you get non-ethanol gas?
na300zx (OH)
17:37:23 04/03/07
MD is not E10 at the stations I've seen. I just buy their
ThunderZ
17:41:33 04/03/07
I would guess it's becasue they were used and
Audioquest
18:02:12 04/03/07
The guy i purchased the used injectors from said 5,000 miles
cjm300zxtt
22:32:26 04/03/07
All I can say is I had over 100k on mine before any failed. (n/m)
Audioquest
08:19:30 04/04/07
I just talked to a local Z guy and he was saying it might be
cjm300zxtt
18:03:35 04/03/07
2nd (n/m)
yobobrox
18:04:55 04/03/07
Can you rephrase that using English (american preferebly)? (n/m)
ni[X]it
18:28:44 04/03/07
your local Z guy is wrong
aliaZ
20:47:23 04/03/07
what does a fuel pump sound like when it starts to go out?
cjm300zxtt
22:30:29 04/03/07
best way to test the pump is with a pressure guage
aliaZ
22:35:40 04/03/07
What about an ohm test?
cjm300zxtt
22:55:18 04/03/07
I don't have my FSM handy
aliaZ
23:08:29 04/03/07
I have my FSM in front of me and it doesnt give a test
cjm300zxtt
23:18:12 04/03/07
You said you replaced the connectors. Get a schematic..
Sleeper_TTZ
03:17:18 04/04/07
I've had 3 of my 6 555's make it 8,000 miles! I'm replacing
bummedoutmonkey
20:34:37 04/03/07
That's funny because I'm convinced that my swearing off
robo (sebring1970)
20:42:55 04/03/07
You replaced them all with used ones.
spddracer
21:25:45 04/03/07
A used injector was damaged in shipping so at first i had
cjm300zxtt
22:21:58 04/03/07
buy rebuilt from autowarehouse.com and get 7 yr warranty
mossyoak
08:32:32 04/04/07
Today after driving to a few different places the Z...
cjm300zxtt
16:12:02 04/04/07
