TwinTurbo.NET: Nissan 300ZX forum - Exactly, the calipers will not work without those
Subject Exactly, the calipers will not work without those
Posted by BigTDogg (MA) on March 27, 2007 at 6:33 PM
  This message has been viewed 246 times.
In Reply To The calipers have tiny seals that go in between both posted by FairladyZ4U2NV on March 27, 2007 at 05:47 PM
Message Two little guys at the bottom. I can't even find the PN because you're not supposed to split them open. Probably have to bring one to a hardware store, and get a couple of o-rings in various sizes. Or measure with dial calipers and order on www.mcmaster.com. You can get the pistons out w/o separating the halves.
I don't think Coz's rebuild kit has them, unless they are in the bag at the top.
Caliper rebuild kit
Find an o-ring that fits (maybe search on here, could have happened before), clean both halves and reassemble using a reasonable torque. If they are AL you don't want to strip the threads. Reasonable is unknown, because the FSM says don't separate. I would think 100 ft-lb is a little high for AL. But IIRC, you have iron, but that's still high for that size fastener.
"...Downpipes own. They own everything...anything...all there ever was and will be...they should be stock on all cars. Screw the environment, emissions, noise! I love them...I shall name my first-born after them with glee..." - SeedyRom 05:13:20 10/03/02
z32baby: yeah, my memory sucks balls
DJ Juiced: What's your memory doing this friday night? ;)
