TwinTurbo.NET: Nissan 300ZX forum - Early Injector rewire for switched power
Subject Early Injector rewire for switched power
Posted by NobleZ on December 19, 2006 at 1:46 PM
  This message has been viewed 1820 times.
Message Found some information from the 300zxclub.com for this and finnally tackled the project with my own little changes. Turned out perfect and my car now only applies power to the injectors when the ignition is turned on.
Est. time it takes: 20-30 mins
Tools and parts need:
10mm/12mm sockets and wrench
1 wire crimper/splicer
16 awg butt splices or soldering iron
16 awg shielded female connectors
1 nissan 4 pin relay (or equivilant other)
4 ft of 16 awg wire
electrical tape and wire loom
1. Always disconnect battery when modifing anything on your Z.
2. Remove the three bolt holding down the fuse box (it will things easier)
3. Now take the wire and cut it into 4 one foot strips and connect it to the female connectors (you can use different color wiring but I chose all red). Then connect them to posts on the bottom of the relay.
4. Locate an empty spot in the fuse box or be prepared to mount it on the side of it.
5. Route the wires through the bottom and under the fuse box but dont mix them up.
6. Now unplug the gray/white connector to the right of the fuse box, and strip back the tape/loom on the female side with the socket about 6 inches.
7. Cut the white/black wire in half and connect each half to the normally open poles on the relay(nissan 4 pin would be 3, 5)
8. Splice back some wire on the heavy solid white wire and connect one side of the normally closed poles to it. Connect the other wire from the pole to a gound in the engine bay.(on the nissan relay I connected the #1 pole to the white wire and the #2 pole to the gruond.)
9. Tape everything up, and add loom if desired and start the car.
10. If all goes well, you now have injectors that wont burn out as quickly.
hopefully this is the first of many things I give back to this forum for helping me out everyday :)
Thank you Twinturbo.net
in other news. thousands of people did not receive their holiday mail.... sources close the USPS said that they believe an interweb site page is responsible for the sabotage that has left its tell tale calling cards jamming their machines...
a spokes person for the interpage in question is quoted as replying to the aleagtions with the following responese.
"false"
- dvlhntr 12/12/06 22:35:35
Santa Coz!! (n/m) - WildBillZx 01:15:24 12/14/06
