TwinTurbo.NET: Nissan 300ZX forum - Not very hard IMO.
Subject Not very hard IMO.
Posted by SniPer (SR-71) on October 23, 2006 at 3:59 PM
  This message has been viewed 197 times.
In Reply To Re: Fix it ASAP. posted by Mister_drifter on October 23, 2006 at 03:49 PM
Message I can remove and replace the MC in less than 30 minutes. The brake booster will take a bit longer considering you have some under the dash work involved.
I think it would be safe to say you could remove the MC and booster much faster and easier than dropping the trans.
A 12mm rachet wrench makes the MC bolts an easy task. You'll also need a 10MM line wrench to loosen the brake lines on the MC.
The booster has 4 bolts (12mm I think) and key/pin connecting it to the pedal.
You will also need all of you wheels removed when you get it re-assembled to bleed your calipers.
Gary
Image Hosting by PictureTrail.com
