TwinTurbo.NET: Nissan 300ZX forum - The scaling factor isn't applied to the calculated flow
Subject The scaling factor isn't applied to the calculated flow
Posted by Ash's Z on October 04, 2006 at 6:03 PM
  This message has been viewed 340 times.
In Reply To Scaling suggests linearity, thats only true at low velocity posted by CaliguyPurdue on October 04, 2006 at 05:51 PM
Message value, which would be incorrect for the reason you mention.
The flowscale correction is applied to the flowscale value before the test is made. The flowscale value is the actual CFM that the machine is flowing. Since this correction is applied to the flowrate the machine is producing, and your final measurement is a factor of flow percent, there is not a linear relationship to the final calculated flow and the correction factor.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
