TwinTurbo.NET: Nissan 300ZX forum - Oil pressure would likely flat-line at 45psi regardless of
LitlElvis
on August 30, 2025 at 11:11 AM
What happens if you remove restrictor in oil cooler line?
posted by ZXoltan
on August 28, 2025 at 07:23 PM
RPM
Full Flow Oil Cooler, block original ports or loop them?
Polishzx
15:17:45 08/26/25
Here's some data to help you decide what to do:
LitlElvis
12:41:23 08/28/25
Great info! I didn't consider the bypass valve in the oil
Polishzx
16:17:00 08/28/25
ZXoltan
19:23:24 08/28/25
Oil pressure would likely flat-line at 45psi regardless of -
LitlElvis
11:11:14 08/30/25
