TwinTurbo.NET: Nissan 300ZX forum - I assume that's manifold air temp from your MAP sensor?
Subject I assume that's manifold air temp from your MAP sensor?
Posted by black300zx on January 04, 2025 at 10:30 AM
  This message has been viewed 365 times.
In Reply To SZ IC temperature drop demo posted by sasha on January 03, 2025 at 09:39 PM
Message What you might be seeing is that the slower moving air at part-throttle driving has time to heat back up after exiting the intercooler (hot engine bay and plenum) and then when you go WOT the higher flowrate results in the plenum temperature dropping closer to the actual IC exit temperature.
