TwinTurbo.NET: Nissan 300ZX forum - For my build, which clutch?
Subject For my build, which clutch?
Posted by blackomega on October 03, 2024 at 12:41 PM
  This message has been viewed 457 times.
Message Hey y'all so I been out of the game for a while... My last clutch was Specialty z but I know they got sold... So I'm just wondering which clutch you guys would recommend for this build in modern times 2024. I think this bill is looking at like 550 on pump gas and like 800 possibly on race gas... TIA... One of these days or months or years here soon I plan on sending it for a full dyno tune but in the meantime I just need to clutch so I'm hoping you guys can point me in the right direction.
CP-Carillo Pistons 88mm (Swain top-coated - PC9)
CP-Carillo H Beam Rods
ACL Race Main Bearings
ACL Race Rod Bearings
JWT 500 Series Camshafts
GT675RS Turbos .64 AR
MSP Manifolds
SZ 3" Down Pipes
SZ 3" Test Pipes
SZ 3" Quad Tip Exhaust
SUSPENSION:
SPL Titanium HICAS Delete v2 / Adjustable Toe Rod Kit
SPL KTS coilovers
SPL rear upper arms v2
SPL front tension rods v2
SPL fender brace
300 Degree front camber kit
ES Anti Sway Bars/Bushings
Specialty Z Subframe Spacers
SSW D5R: F 18"x9" +35 tires 235 / 40; R 18"x10" +45
Nitto NT05R 285/40/18 rears "you are gonna be a lot faster
with those"
OFFENSIVE SYSTEMS:
Z1 Adjustable Exhaust Cam Gears
Z1 58mm Throttle Bodies
SZ Expansion Outlet Pipes (black)
Ash Spec V2 2.5" Inlet piping (black)
Ash Spec V2 Massive Intercoolers
Ash Spec 2.5" Intercooler Piping (black)
Forge Actuators
300 Degree Fuel Rail
Nismo 740 Injectors
Nismo Thermostat
Z1 740|dual intake|93 octane program
Nismo FPR
Apex-i boost control solenoid
Apex-i AVCR
JWT Dual Intake
Selin Dual MAF Translator
HKS SSQV BOVs
Koyo Radiator
Silicone Upper and Lower Radiator Hose (Blue)
Woody's world famous short throw shifter
Specialty Z Max Street Clutch
Specialty Z Segmented Flywheel
EGR bypass
AIV delete
TB coolant bypass
New Nissan Oil Pump
New Nissan Water Pump
New Nissan Timing Belt
DEFENSIVE SYSTEMS:
Win Factory Z32 2pc Aluminum Front Lip/Splash Guard
ValentineOne (hardwired | blacked out | remote display)
Philips 4100k HID low beams
Philips 4200k HID high beams
Kaixen 4200k HID fog lights
Axxis Metal Masters brake Pads
Stainless Steel Brake lines F/R
Stainless Steel Clutch Line
300 Degree Master Cyl brace
Motul 600 Racing Brake Fluid
Bernie's Big Brake Caliper Adaptors
EBC 12.8 350Z Track Rotors
Redline MT-90 Transmission Fluid
Mobile 1 Diff Fluid
Blitz Dual TT
Speed Bleeders for clutch
Z1 HICAS Elimination Fitting
Upgraded Clutch Fork Assembly Kit
Z1 Full Flow Oil Cooler Upgrade Kit (thermostatic adapter and
25 row Setrab core)
ATI Race Dampner
Chromoly Pivot Ball
SZ single long clutch line
SZ Oil Pan (6qt)
BDE Plugs
BDE VTC Intake Cam Gears
HKS SSQV Recirc Fittings
PASSIVE SYSTEMS:
Tectom MD100 Telemetry
Defi BF-Link 60mm Boost
Defi BF-Link 60mm EGT
Defi BF-Link 60mm Fuel Press
AEM EUGO Wideband Air / Fuel Ratio Meter
'99 JDM tail lights
Pioneer Premier DEH-P710BT - Radio / CD / MP3 / WMA /
digital player
Infinity mids and highs
Coustic Amp-215 XR
(2) Alpine Type-R 12" sub
500w Alpine mono amp
ChrisTTZ Boxes and Amp Cover
Twin Z Design Side Skirts
BDE Motor Mounts
New motor built by member "timz"... ;) October 2012
___________________
"If everybody is thinking alike, somebody isn't thinking."
~~ George S. Patton
Exercise your rights; support private gun sales.
DD: La-Z-Link
Matt Sturgeon | Create Your Badge
