TwinTurbo.NET: Nissan 300ZX forum - Yup. I am one of those. Lost an engine to a failure in
Subject Yup. I am one of those. Lost an engine to a failure in
Posted by MixManMash on July 23, 2024 at 1:21 PM
  This message has been viewed 308 times.
In Reply To Most on this site would advise against water injection. Too posted by Mr.Stacy on July 17, 2024 at 07:05 PM
Message water injection system. I even had the "fail-safe" module, but it didn't do its job. When I investigated further, I discovered that the module wasn't designed with fail-safe engineering principles (my background is in electrical controls).
The other issue is you can't guarantee even distribution of water to each cylinder unless you can plumb into each runner. And to get consistent delivery, you essentially need it to work more like a multi-port fuel injection system where the pump is always running and you have 6 injectors that are being pulsed to deliver the correct amount of fluid.
To be honest, if you have access E85, I wouldn't bother with water injection.
