TwinTurbo.NET: Nissan 300ZX forum - Does the noise change when clutch pedal is pressed in?
Subject Does the noise change when clutch pedal is pressed in?
Posted by ZXoltan on April 02, 2023 at 11:43 AM
  This message has been viewed 406 times.
In Reply To 98 spec 5-speed is crap. posted by Good2Zya2.0 on April 02, 2023 at 12:10 AM
Message Noise with the pedal pressed down is typically a throw-out bearing. It sounds like you def have an issue with a trans bearing, but may have an additional TOB problem.
