TwinTurbo.NET: Nissan 300ZX forum - Fuel system - Nuts and bolts ( engine bay )
Subject Fuel system - Nuts and bolts ( engine bay )
Posted by Mike@ZSpeed on February 23, 2023 at 7:28 AM
  This message has been viewed 418 times.
Message 1. When replacing balance tube rings. Is it ok to go with CZP or is OEM superior
CZP --> https://conceptzperformance.com/czp-buna-n-balance-tube-o-ring-set-nissan-300zx-90-96-z32-c14033-30pkt_p_10015.php
OEM --> https://conceptzperformance.com/nissan-infiniti-nissan-oem-300zx-balance-tube-o-ring-set-z32-14033-30pkt_p_1110.php
2. If replacing balance tube nuts (3). Is it ok to go with "dress-up" bolts from CZP, Z-Spec design fastener kit. or is OEM superior
CZP dress up --> https://conceptzperformance.com/dress-up-bolts-titanium-balance-tube-hardware-kit-nissan-300zx-z32-nis-071-ti_p_75461.php
Z-Spec --> https://conceptzperformance.com/zspec-design-balance-tube-fastener-kit-stainlessbillet-hardware-fits-1990-96-nissan-z32-300zx-z32blss_p_65142.php *** reiew says "Two of the screws that mount on the right side of the balance tube (next to the brake booster) aren’t long enough to even thread into the holes…."
OEM --> https://conceptzperformance.com/nissan-infiniti-nissan-oem-300zx-balance-tube-bolt-z32-08120-8202e_p_6280.php
OEM --> https://conceptzperformance.com/nissan-infiniti-nissan-oem-balance-tube-nut-nissan-300zx-z32-01217-00191_p_5507.php
Or
re: Nuts and bolts :Don't bother your OEM nuts and bolts on it now are good enough.
Or
re: Nuts and bolts: Well if your redoing the fuel system and are replacing the balance tube rings migh as well get all new hardware
1990 NA
1993 TT
