TwinTurbo.NET: Nissan 300ZX forum - bulb question (rear signal light)
Subject bulb question (rear signal light)
Posted by VinZmax on January 09, 2023 at 9:01 AM
  This message has been viewed 534 times.
Message I have a rear signal light bulb question....
What bulb do you have in the rear signal lights? 1156?
Here's what I found on my car;
I have a '93 TT (my brother has a '93 n/a convertible).
We were both switching to LED's at the rear. He put in 1156's. When I tried to put in my 1156 LED's, they would not fit. Low and behold, they are 7507's.
That means the base pins are not a 180 degrees opposite each other. They are at 150 degrees opposite.
WTH??? Same year cars. Same OEM US spec wiring harness (I think?).
I looked up the bulb chart for these cars and don't see where they list 7507's for the rear indicator bulbs for '93 TT's.
I sanded off a pin on the LED's and they fit and work fine (needed a different indicator relay to work with the LED's to prevent fast flashing).
*saw this and tried it;
https://www.instructables.com/How-to-Fit-a-1156-LED-Bulb-Into-a-7507-Housing/#:~:text=You%20may%20notice%20that%20the%201156%20and%207507,bulb%27s%20base%20to%20fit%20it%20into%20the%20housing.
Just curious as to why the same year cars (/93 TT vs n/a) would have different rear signal bulb requirements.
All works, but wondering if anyone else ran into this issue.
Z32 Bulb numbers
Low beam headlamp
Part number = 9006
High beam headlamp
Part number = 9005
Parking light
Part number = 1157
Front turn signal
Part number = 1157
Rear turn signal
Part number = 1156
Tail light
Part number = 1157
Stop light
Part number = 1157
High mount stop light (third brake light)
Part number = 912
Fog/Driving light
Part number = H3
License plate
Part number = 194
Back up light
Part number = 1156
Front sidemarker
Part number = 158
Rear sidemarker
Part number = 158
Glove box
Part number = 158
Map light
Part number = 158
Dome light
Part number = 158
Step/Courtesy light
Part number = 158
Trunk/Cargo area
Part number = 158
Instrument-general
Part number = 158
