TwinTurbo.NET: Nissan 300ZX forum - note to the above. DO NOT remove the tension
Subject note to the above. DO NOT remove the tension
Posted by slayer fan on December 02, 2022 at 10:10 AM
  This message has been viewed 417 times.
In Reply To any Ichiko mirror that pivots from the top probably can be posted by slayer fan on December 02, 2022 at 07:29 AM
Message screw from the ball joint. there is a metal piece inside the mirror that the screw threads into. if you do, it will fall out of position, and you will never get the screw threaded back into it. i did this on my first mirror replacement attempt. just loosen the screw and use a little force to pull the base from the mirror and use some force to push the new mirror onto the z mounting base. i hope this helps someone looking to replace their old mirror with one that isn't blackening around the edges.
