TwinTurbo.NET: Nissan 300ZX forum - Re: intake manifold bolt took some threads w/ it! help
Rob260
on June 13, 2022 at 5:53 AM
posted by devsdead Z32
on June 12, 2022 at 02:52 PM
M8x1.25 wire thread insert will be fine for repair
devsdead Z32
14:52:19 06/12/22
Use a Helicoil thread insert...
Denis
16:30:16 06/12/22
Re: Use a Helicoil thread insert...
devsdead Z32
16:47:04 06/12/22
Thread insert...
Denis
18:14:09 06/12/22
sounds good! thank you for the help! (n/m)
devsdead Z32
19:11:21 06/12/22
Re: intake manifold bolt took some threads w/ it! help -
Rob260
05:53:05 06/13/22
Do them all while you' have the lower intake exposed
megaDan
09:36:48 06/13/22
I would replace what is damaged and use a torque wrench to
13:52:21 06/13/22
Will do Bernie (n/m)
devsdead Z32
16:44:19 06/13/22
Amen to that...
Denis
17:11:26 06/13/22
That's a good process. (n/m)
17:32:52 06/13/22
Many times the problem is owners fail to use the
CmyZ
16:18:39 06/14/22
If you Helicoil it, you should ensure it is drilled square
LitlElvis
12:52:47 06/13/22
