TwinTurbo.NET: Nissan 300ZX forum - I go over the gauge cluster and repair, replace and rebuild
Subject I go over the gauge cluster and repair, replace and rebuild
Posted by DVDBURN (MD) on February 25, 2021 at 4:17 PM
  This message has been viewed 994 times.
In Reply To Re: My 92 NA failed @ 7 yrs ago. posted by SRH on February 25, 2021 at 03:08 PM
Message what's needed. After it's complete I test all the functions using my test setup. There are three prices for the repair. $150 for the 90/91 models, $175 for 92+ models if the speedometer board can be repaired and $200 for the 92+ models if the speedometer board needs replacing. I also install my own custom fabricated LEDs for the gauge cluster and instrument pods. $30 for the cluster and $50 for the pods. If you need an ECU or FPC repaired or modified I do that too.
You can see a short video and pictures of my test setup at these links to public posts on my Facebook page. There's been some changes since the video and pictures are a few years old.
Video.
https://www.facebook.com/1270410434/videos/10205970020390852/
Pictures.
https://www.facebook.com/photo?fbid=10205970033271174&set=pcb.10205970040631358
Here is a link to my website which has a few pictures too.
[ http://www.z32tech.com ]
LEDs installed in cluster. Zero hot spots that used to be a problem.
LEDs installed in the instrument PODs.
The low fuel indicator will appear to be lit due to the stray LED light hitting its diffuser but in a low fuel situation it will still light up as normal because the lamp for low fuel is not replaced with an LED.
www.mytwinturbo.com
Nissan Data Voice on YouTube
