TwinTurbo.NET: Nissan 300ZX forum - Re: Oil Pan gasket needs to be replaced >>>>>>>
Subject Re: Oil Pan gasket needs to be replaced >>>>>>>
Posted by Metacom on January 15, 2021 at 8:29 PM
  This message has been viewed 752 times.
In Reply To Oil Pan gasket needs to be replaced >>>>>>> posted by JULIAN on January 15, 2021 at 07:38 PM
Message I did the oil pan on my TT with engine in. Its technically easy but physically difficult.
If you're planning to perform all that other work then remove the engine.
If you do it with engine in, replace the rubber oil return lines on the side of the pan. I also replaced the o-ring for the oil pick up. Good time to replace the steering rack bushings and steering shaft ujoint if needed.
Use air to blow out all the oil from the pan bolt holes, and practice a few "dry runs" putting the pan up because you'll find out it only goes back in at a certain angle and kinda slides against the trans spacer plate...and its easy to knock the front/rear rubber seals outta place if not done just right.
