TwinTurbo.NET: Nissan 300ZX forum - Oil Pan gasket needs to be replaced >>>>>>>
Subject Oil Pan gasket needs to be replaced >>>>>>>
Posted by JULIAN on January 15, 2021 at 7:38 PM
  This message has been viewed 484 times.
Message So I found out today I have a slow slight leak on my oil pan gasket. My mechanic told me the easiest way to replace the gasket is to remove the motor from the top of the car or to drop the subframe. Which would be easier ??? Also what other items should I get replaced while I am in there ?? If the motor has to be removed I was thinking replacing with bigger turbos, and replacing the clutch and flywheel. Any other item you would suggest ?? Since the car does not get driven that much, I plan on just saving for all the parts for the rest of this year and getting it done next year around this time. Thank you for reading and giving any info or advice. God Bless !!!
