TwinTurbo.NET: Nissan 300ZX forum - Could the TPS voltage readings cause the engine to die?
Subject Could the TPS voltage readings cause the engine to die?
Posted by KevinsFairlady on November 03, 2020 at 11:05 AM
  This message has been viewed 531 times.
In Reply To make sure the TPS shaft is machined correctly posted by vorpalZed on November 02, 2020 at 11:21 AM
Message I have the original Rob's throttle bodies and have an issue where the engine will occasionally drop the RPMs so low during deceleration that the engine cuts off. Wondering if this might be a cause...
Fall-Z-<br>Crop
