TwinTurbo.NET: Nissan 300ZX forum - I fixed the problem with the shaft
Subject I fixed the problem with the shaft
Posted by AndrewG on November 03, 2020 at 6:34 AM
  This message has been viewed 1032 times.
In Reply To make sure the TPS shaft is machined correctly posted by vorpalZed on November 02, 2020 at 11:21 AM
Message I bought one of the original 62mm sets and reading about the problems on here took apart an old TPS to see
what was going on. The stock shaft is extends all the way into the female split plastic "D" bush and is pinched
at the top by a round wire snap ring. For some reason the 62mm shaft is short and does not extend up to the
snap ring. This results in the shaft not being gripped properly and allows a small amount of play. I fixed the
issue with a small "L" shaped shim which applies a slight amount of pressure to the bush and removes the play.
