TwinTurbo.NET: Nissan 300ZX forum - Regarding flex sensor.....
Subject Regarding flex sensor.....
Posted by Stanky (BC) on October 14, 2020 at 3:39 PM
  This message has been viewed 430 times.
In Reply To Looking for E85 guidance, other than "Just do it!" posted by Woodnutz (PA) on October 14, 2020 at 09:05 AM
Message I see you don’t have a stand-alone in your profile. If that is true and you are using oem ecu, you will need a map switcher (SZ) to change tunes between different E contents(%). If you plan on getting a stand-alone, it’ll be able to do that for you on the fly once if gets the ethanol input wired to it.
Also, get a walbro pump. The oem one will be close to maxed on e85
