TwinTurbo.NET: Nissan 300ZX forum - Add more water too while you're at it. Antifreeze is a poor
Barry (NJ)
on August 24, 2020 at 4:46 PM
Re: How clean are the fins for the radiator and for the AC
posted by KA8
on August 19, 2020 at 07:34 PM
coolant, and you're not likely to see a lot of freezing temps in your area where you need "Anti-Freeze" in your radiator. I run 70/30 in NJ without freezing.
My Z ran little warm today... suggestions?
KA8
19:01:48 08/19/20
MixManMash
19:29:39 08/19/20
KA8
19:34:19 08/19/20
Fins are not all bent up? Usually, compressed air can
MixManMash
06:17:04 08/20/20
Add more water too while you're at it. Antifreeze is a poor -
Barry (NJ)
16:46:28 08/24/20
A few things
Stanky (BC)
19:51:33 08/19/20
Got it! Thanks y'all
KA8
20:21:20 08/19/20
I'm not so sure on the cooler thermostat. Greg at SZ
MixManMash
06:02:55 08/20/20
Did you pressure check the system?
ZXoltan
06:54:03 08/21/20
Re: Did you pressure check the system?
KA8
09:54:49 08/21/20
Again, did you pressure check the system...
ZXoltan
13:42:23 08/21/20
Recently saw mention of a GKTech Fan blade, anyone know more
nissubaru
21:46:52 08/19/20
Interesting... Could be a bonus for those with cracked OEMs. (n/m)
KevinsFairlady
10:55:53 08/20/20
Make sure your aux fan is functional.
Doug71zt(CAN)
18:49:52 08/20/20
Re: Make sure your aux fan is functional.
KA8
09:57:58 08/21/20
Isn't the OEM gauge & sensor highly non-linear, with
black300zx
08:13:24 08/21/20
Exactly this. (n/m)
Barry(TN)
09:26:48 08/21/20
True. I'd hook up Datascan and actually measure coolant
MixManMash
12:46:38 08/21/20
How accurate is the gauge sensor/sender?
ZXoltan
15:36:25 08/21/20
Data scan reads the ECU sensor not the dash gauge sensor. (n/m)
itsa300zx
16:31:30 08/21/20
Makes sense. But how accurate is that sensor? (n/m)
ZXoltan
16:42:51 08/21/20
Considering the ECU makes decisions on that sensor, it's
MixManMash
17:33:07 08/21/20
Plenty. It reads in single digits. (n/m)
23:24:30 08/23/20
Good to know. thank you sirs.
ZXoltan
10:24:46 08/24/20
Because the dash gauge is non linear. It displays an ok zone (n/m)
13:45:22 08/24/20
I hacked mine with an Arduino uno for fun
black300zx
16:21:36 08/25/20
