TwinTurbo.NET: Nissan 300ZX forum - Heat Wrap Low Pressure A/C Line?
jval
on March 13, 2020 at 7:56 AM
Have the engine out of the car and am cleaning everything up. The wrap on the lower A/C line is mostly all torn up. Can I use exhaust heat wrap all the way from the firewall to the compressor to replace it or does it have to be a more porous wrap?
Heat Wrap Low Pressure A/C Line? -
jval
07:56:18 03/13/20
i wrapped mine with DEI titanium exhaust wrap.
slayer fan
11:05:50 03/13/20
That's what I'm using
jval
11:11:10 03/13/20
no. (n/m)
slayer fan
12:59:47 03/13/20
I used AC line foam then wrapped with heat wrap.
SkiFly01
13:34:34 03/13/20
i used closed cell foam pipe insulation w/ zip ties
Gordo LSZ Daytona
22:07:45 03/13/20
Re: i used closed cell foam pipe insulation w/ zip ties
Kvert
15:55:08 03/14/20
Kvert
15:57:35 03/14/20
Yup. This is a better idea. (n/m)
09:05:20 03/16/20
That crossmember is immaculate. I guess its
ZXRider
20:41:12 03/16/20
Everything underneath was disassembled and either
Gordo LSZ Daytona
18:57:14 03/18/20
Nice. Bernie knows what's up
ZXRider
15:55:04 03/19/20
What do you need? (n/m)
20:15:19 03/20/20
You ever come across a bad fuel vapor vent line check valve? (n/m)
ZXRider
02:07:13 03/22/20
A bad one? (n/m)
01:53:19 03/26/20
One that failed
ZXRider
10:05:23 03/26/20
That's because I can't price match Z1 on those.
09:36:08 03/29/20
Understood. What's your verdict on the
ZXRider
14:54:56 03/29/20
Rubber hose on the fuel tank, bad CC or delete issue, vac
21:34:01 03/30/20
Got a smoke machine. Will use it. Have not used it yet.
ZXRider
20:15:52 04/01/20
