TwinTurbo.NET: Nissan 300ZX forum - Assembly lube on bearing surfaces and cam shaft/lifters
Subject Assembly lube on bearing surfaces and cam shaft/lifters
Posted by ZXRider on February 08, 2020 at 8:08 PM
  This message has been viewed 566 times.
In Reply To Starting rebuilt engine guidance posted by Kvert on February 07, 2020 at 07:38 PM
Message conventional oil on cylinder walls during assembly.
Fill oil, fill oil filter, start it up.
In my case, I removed the plugs and the fuel filter fuse and cranked the engine to build oil pressure, but I don't think it would've done anything different if I had just started it right up. Been getting oil analysis done every other oil change, everything is in good shape.
