TwinTurbo.NET: Nissan 300ZX forum - Wire wheel and clearcoat those throttle springs! ?? (n/m)
Ted (92TT)
on January 21, 2020 at 11:01 PM
Pictures of my 1991 Z32 TT Engine Build Project
posted by 300ZXTCZ
on January 19, 2020 at 10:51 PM
300ZXTCZ
22:51:02 01/19/20
Wow. That's show quality workmanship. Almost too pretty
Gordo LSZ Daytona
08:23:01 01/20/20
Re: Wow. That's show quality workmanship. Almost too pretty
300ZXTCZ
10:07:03 01/20/20
Did you grind the plenum for injector #1 clearance? For >>
ZUL8TR
05:33:35 01/21/20
Re: Did you grind the plenum for injector #1 clearance? For >>
300ZXTCZ
08:11:13 01/21/20
Really with new style injectors the need for grinding is nil
BlackholeZ
21:58:59 01/24/20
rotate the AN fitting elbow 90 deg to the left
vorpalZed
09:17:32 01/20/20
Can you swap the 45 ss line with the 90 ss line?
itsa300zx
11:03:14 01/20/20
Re: rotate the AN fitting elbow 90 deg to the left
300ZXTCZ
12:34:58 01/20/20
Re: Pictures of my 1991 Z32 TT Engine Build Project
ni[x]it
10:00:09 01/20/20
Can you rotate it inboard, towards the pass side? (n/m)
ni[x]it
10:03:57 01/20/20
Re: Re: Pictures of my 1991 Z32 TT Engine Build Project
300ZXTCZ
12:25:33 01/20/20
Please put timing covers on. (n/m)
10:14:09 01/20/20
will have to keep them off for cam gear timing (n/m)
vorpalZed
10:40:57 01/20/20
That's no excuse to be missing the backing plates (n/m)
19:07:26 01/20/20
agreed (n/m)
vorpalZed
19:18:26 01/20/20
Absolutely beautiful! Great job! (n/m)
The Hawk
12:05:13 01/20/20
Re: Absolutely beautiful! Great job!
300ZXTCZ
12:28:05 01/20/20
Looks really nice.
Boosted1
16:51:03 01/20/20
Looked hard for a single spec of dirt to call you out on
Polishzx
21:01:35 01/20/20
Re: Looked hard for a single spec of dirt to call you out on
300ZXTCZ
08:13:49 01/21/20
Ditch the silicone inlet and outlet couplers.
ZXRider
23:33:22 01/20/20
Re: Ditch the silicone inlet and outlet couplers.
300ZXTCZ
08:18:56 01/21/20
Use the search function, or Google it
ZXRider
09:06:27 01/21/20
Re: Use the search function, or Google it
300ZXTCZ
12:06:45 01/21/20
Sent you 300 degree instructions inEmail (n/m)
ZUL8TR
05:09:14 01/21/20
Re: Sent you 300 degree instructions inEmail
300ZXTCZ
08:20:21 01/21/20
I angled that fitting outward a bit to clear the water pipe
Barry (NJ)
13:28:18 01/21/20
Wire wheel and clearcoat those throttle springs! ?? (n/m) -
Ted (92TT)
23:01:59 01/21/20
Other than that, looks great :-) (n/m)
Ted (92TT)
23:05:13 01/21/20
Oooooo shinyyyyy (n/m)
Drk93TT
05:26:52 01/24/20
purdy, real purdy (n/m)
moxie (SF)
10:52:31 01/29/20
