TwinTurbo.NET: Nissan 300ZX forum - The 16bit ecu has more resolution vs the 8bit, plus no AIV
Subject The 16bit ecu has more resolution vs the 8bit, plus no AIV
Posted by Bernie (NoVA) on December 17, 2019 at 8:43 PM
  This message has been viewed 523 times.
In Reply To If that's the case, then I think everything is okay. posted by moxie (SF) on December 16, 2019 at 12:59 PM
Message therefore it's constantly adjusting the timing to minimize idle emissions and keep the cats hot. The older 8 bit ecu is slower and it doesn't flutter the timing as often. Both should be solid when you disable the ecu input to set the base timing. On the 16 bit cars if you bump up the idle a bit the timing will get a little more stable at idle, I usually dial them into 900~925.
Bernie Bilski
berniebilski@cox.net
