TwinTurbo.NET: Nissan 300ZX forum - I reset the timing belt, but I'm still having issues
Subject I reset the timing belt, but I'm still having issues
Posted by moxie (SF) on November 28, 2019 at 10:25 AM
  This message has been viewed 447 times.
In Reply To I pulled the timing belt and confirmed the driver's side posted by moxie (SF) on November 27, 2019 at 01:22 AM
Message I can't get the cars base timing to fall inline, It's WAAAY advanced. Even if I move the CAS as far as it can go, it's still stilling around 20 degrees. And the timing is still skipping around a bit unless I unplug the TPS (Hard idle switch still connected). Then it's rock steady, which makes no sense
I'm tempted to replace the CAS & TPS and see if that's the issue.
What else governs timing? I know the timing belt is good (unless it somehow skipped again, doubtful), so not sure what else it could be
Sig Quotes:
your brillant (n/m) - Zski (Generation Z) 14:36:48 06/17/04
Fat kids will eat anything. (n/m) - SooperZ95 22:13:47 07/05/04
BTW, spelling has nothing to do with being stupid, stupid. - AzHeat 22:08:35 11/21/04
First of all, we already know you're a little pussy bitch from San Francisco - Marshall 21:36:41 06/08/05
North Dakota is so flat you can watch your dog run away from you for 3 days. - BeegsTT 13:31:27 06/15/06
The City of Santa Monica can fornicate itself with an iron stick. - 93TTSuperWHiteZX 17:20:16 10/31/06
I work with fiberglass you stupid f*** - TheTwinZ (Peru) 12:25:30 03/27/07
People who are willing to sacrifice
Freedom for safety deserve neither
- Benjamin Franklin -
Are you in the know?
