TwinTurbo.NET: Nissan 300ZX forum - I feel like Nissan maybe using cheap bearings
Boostjuice
on July 29, 2019 at 5:16 PM
I totally agree, though it does seem like there is a weird
posted by Polish
on July 29, 2019 at 05:08 PM
its for sure a bearing issue. It has been throughout the last 7 years. They had a bunch back in 2012 that had bad bearing problems. I think Harry got a couple a few years ago that were bad as well
98 j spec trans
Boostjuice
00:43:05 07/28/19
Maybe with some time it will get better?
Polish
01:06:56 07/28/19
Redline is not a good fit for new units.
10:52:20 07/28/19
Bernie, concept z says the fluid in the trans should not
Boostjuice
12:02:27 07/28/19
Re: Bernie, concept z says the fluid in the trans should not
OleMissFan
17:23:13 07/28/19
Thanks (n/m)
21:38:38 07/28/19
Because they are in the business of selling fluid? (n/m)
21:38:09 07/28/19
remove the shipping fluid. Install the proper fluid
vorpalZed
23:35:25 07/28/19
hee haw! (n/m)
ForceFedTT
23:39:57 07/28/19
reasoning behind it? Just like to know why OEM
nonstopna
16:38:51 07/28/19
Re: Redline is not a good fit for new units.
Boostjuice
14:57:56 08/02/19
Because Nissan doesn't ship their transmissions filled w. it (n/m)
02:15:53 08/03/19
I have had two of them in my Z
Drk93TT
07:41:48 07/28/19
Same story as Drk93TT here
kickerzx
15:28:26 07/28/19
Yep both mine are
Drk93TT
06:34:27 07/29/19
Why did you remove the Nissan fluid? (n/m)
10:50:50 07/28/19
https://conceptzperformance.com/nissan-infiniti-nissan-oem-9
Boostjuice
11:50:27 07/28/19
I don't buy it.
21:32:17 07/28/19
The one I received from concept did not even have a
Boostjuice
22:30:17 07/28/19
Maybe they are draining them prior to shipping (n/m)
10:59:24 07/29/19
Ironically, I was @ SZ's shop 5 days ago, asked Seb and Greg
ForceFedTT
23:18:58 07/28/19
Didn't even think about break in procedure for the trans(s)
Drk93TT
17:20:15 07/29/19
it wouldn’t have, Ive been taking it easy on it, and
Boostjuice
17:46:19 07/29/19
Re: it wouldn’t have, Ive been taking it easy on it, and
Metacom
19:33:28 07/29/19
Best fluid I have run in a Z32 is the Nissan stuff.
MixManMash
22:33:29 07/28/19
I had the same experience on mine, even my busted up
puchy
11:11:29 07/29/19
How do you know it's the input shaft bearing making noise? (n/m)
LitlElvis
12:02:55 07/28/19
Makes the same whine my 100,000 mile trans did
Boostjuice
12:30:29 07/28/19
Any chance it could be throwout bearing? (n/m)
CameronSF
17:35:09 07/28/19
Throw out bearing is new as well, it came on the trans
Boostjuice
18:19:49 07/28/19
If you really want to isolate it you can do this...
Ted (92TT)
19:05:03 07/28/19
i wouldn't worry about it. my 98 tacoma has done
slayer fan
01:20:44 07/29/19
the reason I ask is there are no less than 6 major bearings
LitlElvis
10:25:10 07/29/19
Throwout bearing makes noise when you push in the clutch
BlackholeZ
20:48:07 07/28/19
I run the recommended mix of long time members...
Oppaman Z
13:12:39 07/28/19
Re: 98 j spec trans
ryzan
06:23:41 07/29/19
I can't see that happening if the pilot bushing in the crank
MixManMash
07:24:19 07/29/19
I put the transmission in myself like I’ve done before
Boostjuice
08:46:11 07/29/19
Exactly. Therefore I'm not sure how it's possible to have a
MixManMash
12:47:03 07/29/19
just wanted to give everyone a heads up that the boxes still
Boostjuice
13:00:27 07/29/19
Re: just wanted to give everyone a heads up that the boxes still
RobZ32
15:39:28 07/29/19
I don't believe the issue is a bad batch.
10:17:26 08/02/19
of course, Amateur Z has no experience with that scenario
vorpalZed
10:30:42 08/01/19
I wonder how much trouble it would be to replace just the
Polish
15:38:44 07/29/19
The bearing is not hard to get to, but I shouldn’t have to
Boostjuice
16:34:23 07/29/19
just search for my video on youtube. bet its the EXACT same (n/m)
Drk93TT
16:52:24 07/29/19
Here’s the video
Boostjuice
17:04:00 07/29/19
Exact same mhm
Drk93TT
20:59:33 07/29/19
Nissan will only warranty the parts if they diagnose it as
21:08:11 07/29/19
Polish
17:08:00 07/29/19
I feel like Nissan maybe using cheap bearings -
Boostjuice
17:16:36 07/29/19
Nissan uses high quality NSK bearings. It would be hard to
10:21:18 08/02/19
I would take the whine over my 4th and 5th gear synchros
outkaZTT
22:03:44 07/29/19
My car sounds like it has a supercharger
Boostjuice
16:35:41 07/30/19
Spoke with Mike Smith @ JWT about his thoughts on this today
22:13:43 07/31/19
Good info thanks for following up (n/m)
Polish
00:07:39 08/01/19
That's great insight. (n/m)
Zeus
09:18:56 08/01/19
I could see that. the next step from what I’ve been told
Boostjuice
11:15:26 08/01/19
Thanks, Bernie. (n/m)
ForceFedTT
10:07:24 08/04/19
