TwinTurbo.NET: Nissan 300ZX forum - Yes the funky idle problem occurred >>>>>>>
JULIAN
on July 28, 2019 at 7:53 PM
Did the funky idle happen immediately after you installed
posted by SirpriZ
on July 28, 2019 at 05:26 PM
right after the installation of the DP/TP. I am having my mechanic perform a smoke test to check for any vacuum leaks.
Installed DP and TP now idle is bad >>>>>>>
JULIAN
21:00:19 07/24/19
New O2s.... Which brand are they? (n/m)
MixManMash
21:03:36 07/24/19
All 4 O2 sensors are NGK (n/m)
JULIAN
21:42:23 07/24/19
I ran those for a little while. Seemed to work well enough
Polish
13:12:27 07/25/19
I've seen cars not idle properly on Bosch units, but
MixManMash
13:21:46 07/25/19
Yes NGK = NTK
Polish
16:28:20 07/25/19
More to do w. them being fouled than which brand. (n/m)
18:55:34 07/25/19
Agreed. I used to play around logging them with Nistune.
ConVerTT
20:07:32 07/25/19
Easy solution. Ditch the narrow bands, go Haltech and
MixManMash
21:22:40 07/25/19
on the list ...
ConVerTT
22:42:56 07/25/19
You have a vacuum leak in the engine bay. (n/m)
23:58:30 07/24/19
Hey Bernie >>>
JULIAN
21:53:50 07/25/19
If it was idling fine before and now it isn't - do not mess
Summeronthechain (MN)
09:22:18 07/26/19
check o2 with ECUTalk......
VinZmax
08:30:52 07/25/19
Thanks VinZMax >>>>
JULIAN
16:55:13 07/25/19
get some carb clean and spray around under hood/intake
Drk93TT
07:01:06 07/26/19
I did this with the hoses that I could see >>>>>>>
JULIAN
19:32:49 07/26/19
did you curse loud enough at it? neighbors should complain (n/m)
15:39:41 07/25/19
When was your last boost leak test done? (n/m)
ConVerTT
10:58:22 07/26/19
About 6 months ago. (n/m)
JULIAN
19:31:36 07/26/19
I'd say do a boost leak test now just to be certain. (n/m)
ConVerTT
00:56:43 07/28/19
What is strange is that after driving >>>>>>>
JULIAN
19:37:49 07/26/19
SirpriZ
17:26:44 07/28/19
Might just need to be tuned to handle the changes.
MixManMash
19:31:00 07/28/19
Yes the funky idle problem occurred >>>>>>> -
JULIAN
19:53:40 07/28/19
If the transmission was out or the motor was able to tilt
21:45:32 07/28/19
