TwinTurbo.NET: Nissan 300ZX forum - Electric Antenna Switch Help Needed
Subject Electric Antenna Switch Help Needed
Posted by SilverZXTT(CO) on June 20, 2019 at 4:50 PM
  This message has been viewed 527 times.
Message Need a little help here with wiring an electrical antenna switch into radio wiring harness. I sent my stock Bose Radio/Cassette player off and got an external input wired into the radio circuit. It is wired such that the radio plays normally until an external input is plugged in then it will disable the radio signal and the external input takes over. All controls work normally with the external input. The problem I have is the antenna is still extended during external input and I want to retract the antenna. Can someone show me the wires to put a switch in and the type of switch needed to make this work. The antenna motor is dual direction, so I would like a switch that raises, neutral, and downward (3-way switch). I know everybody will say get rid of the Bose, it is crap, but I want the stock look inside the car. Besides it works as well as any other stereo and it was designed for the cabin.
