TwinTurbo.NET: Nissan 300ZX forum - When lowered onto a surface tires need to roll abit
Subject When lowered onto a surface tires need to roll abit
Posted by Gordo NA2LS Daytona on February 09, 2019 at 10:55 AM
  This message has been viewed 446 times.
In Reply To Build some Nixit Blocks... posted by Barry (NJ) on February 07, 2019 at 03:20 PM
Message to fully settle. If the blocks could slide in and out, then they'd work.
What I did, was measure the axle angle fully loaded on the ground (1 degree down); and then disconnect the lower spring perch while supporting each axle at that same angle. This way I was able to replicate the position of each arm, while have the benefit of extra room to work w/ the wheels removed.
_________________________________________________
