TwinTurbo.NET: Nissan 300ZX forum - Offset is only half the problem .......
Subject Offset is only half the problem .......
Posted by zx299 on December 17, 2018 at 4:17 PM
  This message has been viewed 291 times.
In Reply To Wheel Fitment question 17 x 9.5 20mm Offset >>>>>>> posted by JDELUNA on December 17, 2018 at 12:44 AM
Message MikeD is pretty much 'on the money', anything around the 35-38mm offset will set you up on 17" rims ....... BUT, the oem front calipers are pretty bulky and you can run into clearance issues with aftermarket wheels.
The only surefire way to check for clearance is by test fitting the front wheels on your zed
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
