TwinTurbo.NET: Nissan 300ZX forum - The only problem with the Autodream solution is that
MixManMash
on November 15, 2018 at 9:33 PM
SpecialtyZ has been working with Autodream on theirs.
posted by PiotrC70
on November 15, 2018 at 08:32 PM
you're still trying to measure crank position at the CAS. Which means you are going to still have potential for timing inaccuracies due to many factors, including a bit of slop in the timing belt.
CAS delete....what trigger setup?
Madhatter10-6
21:14:54 11/14/18
36-2 as pr HPA reply... (n/m)
kickerzx
05:31:02 11/15/18
Thanks....
Madhatter10-6
14:12:48 11/16/18
Happy to help.
kickerzx
14:48:33 11/16/18
Re: CAS delete....what trigger setup?
ouikikazz
08:17:40 11/15/18
It replaces the crank pulley. Like the ATI dampers
kickerzx
10:46:34 11/15/18
Re: It replaces the crank pulley. Like the ATI dampers
ouikikazz
11:12:54 11/15/18
If you want to run teh engine sequential you still
kickerzx
11:22:44 11/15/18
TYPO ABOVE!. You need a single tooth on the CAM (not crank) (n/m)
kickerzx
11:23:47 11/15/18
have you thought about electromotive?
Frldy_Z
09:44:27 11/15/18
What CAS related issues are you having?
DVDBURN (MD)
18:53:53 11/15/18
Re: What CAS related issues are you having?
Madhatter10-6
14:11:34 11/16/18
PiotrC70
20:32:09 11/15/18
The only problem with the Autodream solution is that -
MixManMash
21:33:56 11/15/18
