TwinTurbo.NET: Nissan 300ZX forum - Re: Oil Catch Can mounting locations
Subject Re: Oil Catch Can mounting locations
Posted by vorpalZ on August 29, 2018 at 5:46 PM
  This message has been viewed 1770 times.
In Reply To Oil Catch Can mounting locations posted by TTwinZ (CT) on August 28, 2018 at 01:20 PM
Message SZ kit mounted on the drivers side... bottom of the frame rail, there's a 10mm bolt for the mounting band. Re-routed the recirc blue vacuum line later as it was kinked in this pic. I also replaced the supplied 90 deg fitting with a 45 deg one so the DS PCV hose mounts up easier:
Front view with fascia on:
Cut a 2" hole in the lower shields for the draincock access... was sloppy on the side shield cut but the grommett holds it in place:
Bottom view:
