TwinTurbo.NET: Nissan 300ZX forum - I mean only the rear differential mount bushings. These are
SirpriZ
on July 26, 2018 at 10:06 PM
Sorry, re-reading your post, are you saying people swap the
posted by Inzane
on July 26, 2018 at 09:55 PM
main culprits of the noise transmission. Any other bushings in the subframe that are solid and swapped for something "softer" (ie. Urethane or delrin will also help, but aren't the main culprits).
Leader Gears - Owners Poll on Gear Oil
Inzane
18:52:15 07/26/18
Hi Jason, I remember you, though it's been a long time. You
SirpriZ
20:11:50 07/26/18
I recall reading how they needed to be shimmed precisley
20:40:20 07/26/18
Similar boat for me other than I just lived with it rather
Inzane
22:01:25 07/26/18
This post-it note has survived 10 years in my desk...
22:03:08 07/26/18
You hit the main "sin" in setting up the diff correctly on
SirpriZ
22:50:12 07/26/18
I do recall following your strict break-in regiment to the
Inzane
23:02:59 07/26/18
It's risky trying to set up gears that have a wear pattern
SirpriZ
23:38:57 07/26/18
As ideal as that sounds in terms of solving the problem,
Inzane
00:16:23 07/27/18
Re: As ideal as that sounds in terms of solving the problem,
14:12:17 07/27/18
This.
MixManMash
21:40:50 07/26/18
*differential. (n/m)
MixManMash
22:04:04 07/26/18
That would be a good experiment, to swap your
Inzane
22:20:01 07/26/18
Nope. I have another stock one that I am planning to
MixManMash
22:24:06 07/26/18
thats handy. Is it ready to go with all bearings
Inzane
22:36:24 07/26/18
I haven't taken it apart, so it is together. I think there
MixManMash
06:21:10 07/27/18
If you only need the stock ring and pinion, I have a set of
SirpriZ
23:42:28 07/26/18
Hi Mark. It’s been a while. The reason I’m asking about
Inzane
21:50:41 07/26/18
Nismo bushings would be my choice - pricey but quality (n/m)
21:57:34 07/26/18
for both front and rear diff carrier positions? (n/m)
Inzane
22:02:21 07/26/18
At a minimum the front ears on the diff, and stock in the
22:06:02 07/26/18
Does Nissan sell the diff carrier bushings separately?
Inzane
22:26:35 07/26/18
Front bushings for the diff are available from Nissan but
00:56:48 08/02/18
Exactly! (n/m)
SirpriZ
22:58:09 07/26/18
Hi Jason, Even the urethane will transmit a decent amount of
SirpriZ
22:19:48 07/26/18
Thanks. I’m willing to consider anything. Starting with
Inzane
22:44:45 07/26/18
I have driven in a car with just a Quaife. No whine or
MixManMash
06:22:47 07/27/18
My Quaife is quiet. (n/m)
xpwarrior
23:39:20 07/27/18
Inzane
21:55:04 07/26/18
I mean only the rear differential mount bushings. These are -
SirpriZ
22:06:03 07/26/18
So you’re suggesting I get rid of my ES diff bushings first
Inzane
22:23:44 07/26/18
Absolutely. I'm going to find an in depth post with research
SirpriZ
22:54:32 07/26/18
I remember Bernie commenting 1 time on his Leader oil choice
Waco300zx(DFW)
21:13:48 07/26/18
Redline has a 75w140 now too. My diff was never too noisy
22:00:34 07/26/18
Glad you have a quiet rear end :-) (n/m)
SirpriZ
22:56:28 07/26/18
haha (n/m)
ForceFedTT
10:54:51 07/27/18
Also Nissan now has a 75w140 available too...
22:08:23 07/26/18
That will come in handy if I can’t source the Richmond oil
Inzane
22:32:01 07/26/18
I favor using a manufacturer's suggestion for their product.
SirpriZ
22:13:05 07/26/18
Agreed—I have always ran stock TT Diff’s.
Waco300zx(DFW)
22:39:28 07/26/18
Additional Richmond gear info:A friend of mine put a
SirpriZ
23:23:55 07/26/18
found it, thanks,
Inzane
00:10:59 07/27/18
this is why i'm just leaning towards dropping in
Adam (NoVA)
08:23:12 07/27/18
Keep leaning. (n/m)
10:03:18 07/27/18
Unimog portal axle or GTFO
vorpalZ
10:45:18 07/27/18
This. Apparently you can get them on the G-Class. (n/m)
MixManMash
11:18:09 07/27/18
SZ put Redline in both of my Leader diffs...
ForceFedTT
10:53:14 07/27/18
Sent mine to SZ about 5 years ago...
Z ONLY1
13:32:42 07/27/18
Unless batches changed, I did mine about 10 years ago
PiotrC70
14:09:47 07/27/18
My 2 cents...
TTkeeper
13:57:16 07/27/18
Re: Leader Gears - Owners Poll on Gear Oil
ni[x]it
09:28:28 07/28/18
Thanks for chiming in. Yours was one of earliest accounts
Inzane
11:17:17 07/28/18
I should mention,
ni[x]it
08:09:53 07/30/18
Are your diff bushings aluminum? (n/m)
Inzane
09:51:35 07/30/18
Hi Nick! (n/m)
SirpriZ
12:44:29 07/28/18
Mark, you're better then the best! (n/m)
ni[x]it
08:10:09 07/30/18
Blush. Hope things are well in your world. (n/m)
SirpriZ
13:17:18 07/30/18
