TwinTurbo.NET: Nissan 300ZX forum - check your knock sensor for corrosion and replace.
PiotrC70
on June 29, 2018 at 2:49 PM
Maintenance with lower plenum off...
posted by s_zero99
on June 29, 2018 at 03:52 AM
don't forget the di-electric grease + new harness for it as well.
1993 TT. R.I.P. 09.15.2010
s_zero99
03:52:24 06/29/18
Can't really "delete" those water lines
Barry (NJ)
06:08:11 06/29/18
Those 2 feed the turbos.
06:44:00 06/29/18
Aluminum lines I assume? Do you flare the ends
ZXoltan
08:39:33 06/29/18
yes I flare the ends. (n/m)
10:40:41 06/29/18
I do the same with stainless tubing, flared ends (n/m)
-Grimm-
10:52:43 06/29/18
5/16" Aluminum line.
Woody75 (Denver)
12:40:16 06/29/18
A 39 or 45 deg Flare tool or a reamer/ bead tool? (n/m)
Zbullet
16:34:21 06/29/18
Bead is actually what I was thinking of, but this seems
ZXoltan
12:46:09 07/01/18
I used a brake flaring tool
-Grimm-
13:49:37 07/01/18
Like this one?
ZXoltan
14:00:34 07/01/18
I used a basic kit like this for years
Woody75 (Denver)
08:40:30 07/03/18
Yeah pretty much like that. Think I bought it from Autozone (n/m)
-Grimm-
09:41:47 07/03/18
I use this Eastwood one
Woody75 (Denver)
08:12:20 07/02/18
thanks Tim. Does that form a bead or only flare the end?
ZXoltan
12:02:58 07/02/18
Does both as far as I know. I only use the bead/bulb setting (n/m)
Woody75 (Denver)
08:03:41 07/03/18
Cool.... thanks guys. I'll prob buy a cheap tool and
ZXoltan
10:04:22 07/03/18
Re: Maintenance with lower plenum off...
JRFITZ
08:02:29 06/29/18
check your knock sensor for corrosion and replace. -
PiotrC70
14:49:47 06/29/18
true (n/m)
08:23:50 07/01/18
s_zero99
17:18:02 07/01/18
Bernie, do you offer the formed tubes as a service?
ZXoltan
12:09:08 07/02/18
Cheap flaring tool from Harbor Freight will work as well. (n/m)
Woody75 (Denver)
08:05:13 07/03/18
Agreed (n/m)
23:29:20 07/03/18
Lifters should feel solid when you press on them
-Grimm-
09:43:21 07/03/18
I rerouted my DS turbo hardlines
Zbruh92
23:08:22 07/06/18
