TwinTurbo.NET: Nissan 300ZX forum - I doubt Stankys failure was rod failure - more rod bolt fail
Subject I doubt Stankys failure was rod failure - more rod bolt fail
Posted by Doug71zt(CAN) on June 07, 2018 at 6:44 PM
  This message has been viewed 545 times.
In Reply To Stankys let loose at 600ftlbs on e85. posted by Boostjuice on June 04, 2018 at 07:35 PM
Message If he had OEM rod bolts, I expect the engine would still be together. There is a tolerance issue with ARP rod bolts in the VG. They are a loose fit in the rod and cap, where the OEM are press fit. The rod cap can walk and tear things up. I won't build a VG with them.
That said, if you are hitting for the fence, power-wise, buy a set of Carillos or Pauters and forget about that issue.
I just had Pauter build me a set of rods for a Bentley rebuild for less than the cost of two factory rods. No comparison in strength and quality.
