TwinTurbo.NET: Nissan 300ZX forum - It could be like a N/A with low compression
Subject It could be like a N/A with low compression
Posted by not4resaleZ on May 08, 2018 at 3:22 PM
  This message has been viewed 353 times.
In Reply To I get that the curves are different, but I would still think posted by GrecV2 on May 08, 2018 at 01:19 PM
Message (like the turbo engine has) and really tall gears. That would be my fear if it has big turbos and you try to drive it normally. The big turbos wouldn't help launch unless you really got the rpms up and dumped the clutch.
Look at the Specialty Z blog where they show the torque curves of the larger turbo cars. Some setups might work ok, but some of the really high HP cars would be bad. I see two cars with about 200 ft lbs at 3000 rpms. One is a N/A and the other makes 830 HP. I suspect neither would be fun to get rolling at that gear ratio.
