TwinTurbo.NET: Nissan 300ZX forum - Yep. If the engine is out, flip it over, pull the oil pan,
Subject Yep. If the engine is out, flip it over, pull the oil pan,
Posted by MixManMash on March 16, 2018 at 5:53 PM
  This message has been viewed 400 times.
In Reply To Crank and rod bearing replacement posted by njz on March 16, 2018 at 04:00 PM
Message pull the oil pump and rear main seal retainer. Undo all the rod caps and separate the rod from the crank. Pull the crank girdle and crankshaft. Replace the main bearings, reinstall crank and girdle. Replace rod bearings and reinstall onto the crank. Reverse the remaining steps.
