TwinTurbo.NET: Nissan 300ZX forum - install an oil pressure gauge if it's a real concern (n/m)
The Devils Z
on March 02, 2018 at 9:50 AM
Copy that. I guess I'm just used to building older motors...
posted by GrecV2
on March 02, 2018 at 09:13 AM
Motor really has to be raised/come out to change oil pump?!
GrecV2
06:42:47 03/02/18
Mounts likely need changing too...
ConVerTT
07:38:13 03/02/18
x2
Schmeal (NV)
12:16:30 03/02/18
As I recall, mounts could be done using a strut tower lift
jzack
15:03:27 03/02/18
by then, you're 3/4 the way to just pulling the engine
vorpalZ
16:05:21 03/02/18
Ok, thought it could be done by just removing the tranny
jzack
17:38:27 03/02/18
It's the stuff you need to remove before you can change
MixManMash
07:42:37 03/02/18
I’m calling BS Mixman....
ConVerTT
07:52:17 03/02/18
... clutch upgrade last Monday after work ...
vorpalZ
10:11:40 03/02/18
I knew it! (n/m)
ConVerTT
11:37:47 03/02/18
No reason to pull the engine to change pump.
nissanguyz32
08:09:14 03/02/18
Why - leave the pump alone. (n/m)
08:47:02 03/02/18
Exactly. If it ain't broke... (n/m)
MixManMash
08:58:08 03/02/18
GrecV2
09:13:21 03/02/18
install an oil pressure gauge if it's a real concern (n/m) -
The Devils Z
09:50:42 03/02/18
Why is the oil pump not included on the 120k maintenance? (n/m)
nonstopna (SoCal)
09:30:30 03/03/18
Because it's not accessible.
18:45:54 03/04/18
back to the larger point ...
ConVerTT
11:40:14 03/02/18
Full 120k, inspect / clean or replace various electrical...
GrecV2
12:38:20 03/02/18
Doing a ‘90 right now - engine out
ConVerTT
13:04:56 03/02/18
Uhh... I need a space like THAT to work in! (n/m)
GrecV2
14:03:20 03/02/18
It’s super messy now - tried to cram to much crap in it (n/m)
ConVerTT
18:18:31 03/02/18
Yeah, must be nice! Tired of this ship in a bottle lifestyle (n/m)
DanimalZ
19:14:19 03/02/18
#garageenvy (n/m)
Madhatter10-6
10:06:00 03/03/18
It's not a garage. It's a transportation centre with a
MixManMash
08:54:15 03/04/18
you haven't seen the freezer door addition between bays
vorpalZ
10:01:36 03/06/18
way too clean a work space. You need to dump some fluids on
Inzane
22:55:12 03/08/18
It doesn't have to
-Grimm-
15:50:27 03/02/18
