TwinTurbo.NET: Nissan 300ZX forum - One common weak point are the electrical connectors and
Subject One common weak point are the electrical connectors and
Posted by jzack on February 28, 2018 at 9:02 AM
  This message has been viewed 350 times.
In Reply To Getting a survivor 1990 TTZ truly road worthy...? posted by GrecV2 on February 27, 2018 at 06:53 PM
Message cracked weather seal boots. Corrosion gets into the connector contacts and can cause all sorts of ECU error code chasing. When replacing various sensors, not a bad idea to splice in a new connector too --- applies to the injectors as well.
Rear crank seal leaks are also a common issue along with valve cover seal leaks. But you'll need to drop the tranny or pull the engine (for oil pump servicing) to access the rear crank seal.
