TwinTurbo.NET: Nissan 300ZX forum - Each amp has power (12VDC & Grd) and 2 signal
Subject Each amp has power (12VDC & Grd) and 2 signal
Posted by JMartz on February 27, 2018 at 6:12 AM
  This message has been viewed 290 times.
In Reply To in order to bypass what do i have to do? posted by Boostjuice on February 26, 2018 at 09:27 PM
Message wires from the head unit. They both go into the amp. You will have to remove and open each enclosure, snip the signal wires at the amp coming from the radio and connect them directly to the speaker. If you have a post 1990 car no snipping will be required as all connections inside the enclosures are plug-ins. Just pull the two wires you need and make a short harness between them and the speaker,
