TwinTurbo.NET: Nissan 300ZX forum - Transmission mount. (n/m)
ttz'in (norcal)
on July 21, 2017 at 1:46 AM
What else with clutch
posted by nelso419
on July 20, 2017 at 04:55 PM
nelso419
16:55:40 07/20/17
Engine rear main seal, trans front seal & gasket, 350Z fork (n/m)
18:27:02 07/20/17
Wouldn't you also replace the rear oil pan seal?
not4resaleZ
16:17:15 07/21/17
Can that be done independently of dropping the pan and
ZXoltan
16:24:22 07/21/17
Yes. Just remove the plate that the rear main seal sets in.
not4resaleZ
16:55:54 07/21/17
It's a little tricky, but this post helped me.
not4resaleZ
17:09:21 07/21/17
Re: It's a little tricky, but this post helped me.
nelso419
09:29:39 07/22/17
350Z fork is cast, rather than stamped, so it flexes less (n/m)
ZXoltan
17:08:03 07/23/17
Brass bushings will degrade the driving experience. A new
ForceFedTT (SoCal)
18:44:10 07/20/17
SOLID Shifter Mount Kit (n/m)
Jiro
20:53:24 07/20/17
Transmission mount. (n/m) -
ttz'in (norcal)
01:46:07 07/21/17
Flush trans fluid and refill with MT-85
Polish
03:04:45 07/21/17
Re: Flush trans fluid and refill with MT-85
nelso419
08:31:30 07/21/17
The OG guide is at www.ttzd.com in the tech section
Polish
12:59:02 07/21/17
Second on the sport street. (n/m)
Nate (NoVA)
09:11:04 07/21/17
Re: Second on the sport street.
nelso419
12:45:32 07/21/17
Sport Street will handle more HP. Stock will slip with...
Nate (NoVA)
18:56:56 07/21/17
Re: Sport Street will handle more HP. Stock will slip with...
nelso419
09:21:38 07/22/17
No. The sport street is a better product overall. (n/m)
17:18:10 07/23/17
Whats the word on MT-85 vs MT-90?
ZXoltan
11:26:47 07/21/17
"On a regular budget minded fluid I like to recommend Redlin
Polish
12:32:15 07/21/17
Replace the rubber coolant hose that runs on driver side
Drk93TT
07:32:44 07/21/17
Re: Replace the rubber coolant hose that runs on driver side
nelso419
09:36:28 07/21/17
Re: Re: Replace the rubber coolant hose that runs on driver side
Metacom
11:20:27 07/21/17
Another option is get your OEM flywheel resurfaced for cheap (n/m)
Polish
13:10:04 07/21/17
I've got a lightweight flywheel I like. But most would
Nate (NoVA)
18:58:58 07/21/17
Ohh yeah !
Drk93TT
23:23:19 07/21/17
