TwinTurbo.NET: Nissan 300ZX forum - The rear subframe of a civic does not mount the subframe
Subject The rear subframe of a civic does not mount the subframe
Posted by NNayak on March 15, 2017 at 11:45 PM
  This message has been viewed 395 times.
In Reply To Rear subframe question concerning solid bushings and spacers posted by LivinTheDream on March 15, 2017 at 04:14 PM
Message The primary purpose of the rear subframe bushings on the Z32 is to isolate the passenger compartment from the frequency spectrum generated by the driveline, specifically the rear differential geartrain and the rear portion of the driveshaft.
Being that a civic is a front wheel drive car, the rear subframe does not house any drivetrain components and therefore can be hard mounted to the chassis. Road frequency inputs are damped out by the control arm and damper mount bushings. Note also that the front subframe of the Z32 is also hard mounted to the chassis for the same reason.
In the civic, the drivetrain noise is isolated from the chassis by having rubberized engine and transmission mounts.
